rwoofer
Having just bought a new and expensive anchor from my local chandlery, the subject of tripping lines came up to protect my investment.
I expressed my concern at the hassle of dealing with tripping lines, when the chandlery chap told me what he thought was the best tripping line method. He said that
- the main chain rode should be attached by a shackle to the tripping line fixing hole on the anchor
- the chain should be stretched along the anchor shank and a thin line (with a breaking strain say of 100kg) used to attach the main anchor attachment point to the adjacent chain link
The theory is that the thin line only has to keep the anchor angle correct whereas the main loading is taking by the chain all the way to the tripping fixture. If the anchor gets fouled, you simply haul on the rode till it's taught and then motor to break the thin line, allowing the anchor to be hauled up from the tripping point.
All sounds plausible when the anchor is correctly aligned in the direction of the pull, but what about when the tide turns and the boat tries to turn the anchor. Surely this would break the thin line?
Has anyone used this method of tripping line? Does it work?
