Warpa
I have been messing around trying to 'get it right' for a few weeks now to no avail. My old outboard on my little dingy years ago was childs play, get the boat onto a plane then look at position of leg, move pin to adjust.
Maybe its the choppy Solent making things more difficult, when on a plane i trim up a few clicks and all that happens is engine revs go up, speed doesnt see to alter. I tend to go by conditions of the sea and my bow height and with the leg right down the bow is always at what i concider a good height so as not to bring on water.
With the leg fully lowered the waves break just behing the helm on a 17' boat generally with 3 people on board. Is it a case that a boat of that size in choppy water will not really benefit from adjusting the trim?
Another thing i noticed this weekend; while i normally travel at around at between 2 and 3k rpm i opened it up to 4k rpm heading back for the kids and it seemed to stay on top of the waves whereas at 2.5k rpm heading in the same direction we were riding them more than skimming over them.
This is with a mercruiser 3L and quoted top speed 40.8 and cruising speed 29.3, i have an ss prop so not sure if it differs from the original, engine wot is 4.4k to 4.8k rpm.
When at 4k rpm its the 1st time i have pushed the engine that hard, its fully serviced and looked after and i must say was a whole new experience in speed, oil pressure remained stable and its only at 3k rpm that the engine temp actually starts to go up.
Would i be right in thinking if i keep a check on the temp i can run wot for say 5 or 10 mins at a time? I cant find what the cruising speed rpm is on the net
Or could i go wot from hamble to the iow without stressing the engine?
I dont want to cause any damage as im hoping to upgrade and that will go out of the window if i have engine rebuild costs
Sorry about the waffle, just want to get more of an understanding on how things work
