photon
Active Member
Unless you have a Boom Crutch ( whats one of those?) you will often hear your topping lift humming as it is bearing the weight of your boom with tension also from mainsheet and kicker. The cause is turbulence in the wind passing over the halyard causing cavitation and thus vibration.
Slackening tension in the main sheet can reduce the resonance but at the cost of the boom slopping around in any rolling motion.
I have found a trick to damp the resonant frequency.
Support the boom and let off the topping lift to the maximum that your halyard allows at the mast. With a good hank of topping lift to hand simply wrap a spiral of 4mm cord around the topping lift maybe 20 turns or so extended down from the highest point accessible to the point of attachment to the boom securing both end with an appropriate knot or cable tie. Re-rig top the boom and enjoy a quiet glass of wine
The effect is dramatic.
