Anyone had any experience with treadmaster cleaner ? is it any good? its on special for 2ltrs for £10 including delivery in the uk, is it worth buying or does everyone just use fairy liquid?
I have just bought some too (not the offer though!) so I will be interested if anyone has any results to share also. Especially on what strength / dilution.
Just helped a friend clean his 20 year old treadmaster. Used a pressure washer with fresh water only. We ran a test and even at the most powerful setting, up close, there was no damage at all. Took minutes, looks perfect - not an advisable solution if the treadmaster is down below though.
Same here. A pressure washer works well. To avoid the risk of lifting the edges up, I directed the jet away from the edges ie working from the middle of each section outwards. My Treadmaster is 29 years old!
Thanks for the replies i'll try the jet washer (gingerly incase it starts to rip it up) and if that doesn't work for a tenner i think i'll give the cleaner a go.
