matt_b
I'm after some advice on refitting the transducer for a Lowrance X65 fishfinder.
It is a transom mount device but got snapped off the other week due to the anchor rope. The trouble I have is remounting it under the water - there is no easy way to get the boat out and ideally I would like it in the boat so this can't happen again.
Problem 1: To get it into the boat I will need to cut the cable - how should I re-join the co-ax cable and will it still work ok?
Problem 2: Will a transom mount transducer send the signal through the hull ok
Or do I just buy a new transducer at £75 - :-(
