rotrax
When I get a problem, I shall, of course, be checking as you suggest. In the absence of any problems I shall continue to use my boat as usual. If it aint broke, dont fix it.I used a 316 bolt to connect an anchor winch cable through a bulkhead, The resistance at the joint was sufficient to ignite surrounding woodwork.
Now replaced with brass.
It is interesting (and concerning) to check voltage drop across connection when under load.
As an aside, when I fitted my used 8KW Westerbeke genset, I needed to extend the live and earth cables as the battery was 35mm shallower. I made two shaped connectors from 25mm X 2mm Stainless Steel strip. Each was about 70mm long. I connected them with 8mm S/S bolts and nuts. No discernable volt drop on my instruments when cranking the genny, never yet failed to start in 5 the years since fitting. There is no heat at my custom made terminal connectors either.
On the other hand, I am often criticised for tightening threaded fastners so others cannot undo them..................................
