John100156
Agree with above, I had a holding tank fitted to my T34 before it was transported to SCM, it was also a Mk2, so if you need any images I will see if I can dig them out.
We did not have AC on our Targa and it was unbearable at times in summer, you could go for a portable which rejects heat through say a 75mm of 100mm hose, but much better to have one fitted.
Not sure if you would need two AC units though, having had a T34 I would definitely go for just cooling the saloon with the fan drawing air back from there and the two cabins, with a relief path for supply air into each cabin, the downside is control point of course, if one cabin wants it warmer/cooler etc, but one would suffice. 16k btu/hr would be more than enough. You could even go one size down, but the more cooling the better!
