Refueler
So what if you shorten the 18-inch dimension? Force will not be an issue for most boats. I've seen installations as short as 13 inches, but their reason was geometry (small boat). You can always adjust the gain and damping defaults.
The older AH units such as I have .... the Sea State can be altered - but not gain / damping as separates.
Shortening the 'rod' ? I don't think that would be a good idea .... the solution for smaller boats when the AH units were current - was a bracket to mount the unit at designed rod length..... not to shorten. Of course the same 'extensions' to screw into rod were available and carried over to the ST series.
