Pete7
He was, but I like rambling, digressing and generally drifting about.
On an internet forum surely not, ramblings should be kept for evening in front of log fires with single malts
If you want to steer manually you just lift the pushrod off the pin on the tiller and let the tillerpilot just dangle or spin it out of the way.
Not suitable for using on a quadrant as you won't be able to steer manually without going below and lifting it off the pin.
When not in use I and I guess everyone else unrig them and put them somewhere safe. It takes moments - unscrew the plug and lift off.
They have a reputation for not being waterproof. I protect mine in a raincoat.
It sounds like you need a beefier below deck pilot system which will cost you ££££.
Have you got any pics of the pilot in its raincoat?
You'll be telling me it's pink in a moment.
But again, not related to the weight of the boat so a bit of common sense can be applied to the purchase.
I feel someone needs to add that the weight or mass of your yacht is utterly irrelevant to these devices since the device doesn't steer the boat. Your tiller and rudder will continue to steer the boat and as such it is the force required to move the tiller that would change and this is not necessarily related to boat size or weight but rather the design of the system. If your boat can be steered in any weather using your little finger then you don't need anything more than the lowest model. If on the other hand you need two people pushing with all their might then none of the models will help you.
Does anyone know for a fact that the higher models are capable of more thrust? The article in the mags recently Appeared to use a 40kg scale and concluded that the thrust was 40kg so wasn't convinced of that!
