danieleither
I have a 2006 Fairline Targa 40. It has the original Sleipner bow thruster (fitted since new). In late 2020 I had a new Sleipner stern thruster added, along with remote controller and a new double joystick (to replace the old single one). No doubt someone will feel the need to comment this is unnecessary on a 40ft boat with outdrives, however 95% of my boating is solo and having remotely controlled bow and stern thrusters is a godsend when solo mooring, especially in windy conditions and strong tides.
The symptoms of my issue keep changing, therefore not a straight-forward description of the problem, however here is a summary of what happened:
Some videos here to demonstrate some of the symptoms:
Bow thruster motor juddering of own accord
Bow thruster motor juddering, operation of joystick stops juddering momentarily
Stern thruster working, bow thruster NOT working
Bow thruster working, stern thruster NOT working
I contacted the installer who sent a Sleipner-qualified engineer. Before inspecting, they suggested it is probably to do with the solenoid on the bow thruster which can get stuck and cause problems like this. As the symptoms keep changing, I was sceptical of this. Whilst I'm not an expert or marine engineer, the fact that the symptoms kept changing suggested to me an electronics failure as opposed to mechanical, and my thought was it could be the remote module failing (as this can ultimately produce signals which can influence operation of both the bow & stern thrusters, AND contains electronics / circuitry). Anyhow, they came out to inspect and on arrival to the boat everything was working normally and they've stated they are "unable to find anything wrong with the system". This was around 2 weeks after the faults occurred, and the boat hasn't been used inbetween. They did inform me that the engineer had noticed some water / liquid in the engine bay, near to the bow-thruster emergency stop button and suggested this could have caused some problems if it had got wet.
Right now, everything is working properly again however I feel the likelihood of this happening again is high, and therefore I have little confidence to take the boat out.
Has anyone experienced anything similar or can point me in the right direction as to what could have caused this? If it's possible to determine what 'could' be causing this by process of elimination, I'd rather spend some money and replace it than risk colliding with other people's boats.
- Having returned to my home berth, while tying off the lines the bow thruster started thrusting to starboard at full power of its own accord. My initial thought was I was inadvertently pressing a button on the remote, however I checked, and this was not the case as the remote was dangling freely from my neck. This lasted a few seconds before stopping, again of its own accord.
- After securing the boat, I powered everything down and back on again. After powering back up, at first, the stern thruster was working normally, however neither the joystick or remote control would activate the bow thruster.
- I powered down, removed the joystick from the helm to inspect the connections: no corrosion, no loose plugs. Unplugged everything, sprayed contact cleaner and plugged back in, repeating the process for connections on the remote receiver module.
- After the above, the bow thruster now worked perfectly (from joystick or remote) however nothing from stern thruster, however pushing the joystick left or right resulted in the amber light on the joystick dimming and flickering (whilst the joystick was pushed either way). Pressing the remote would not affect the amber light.
- Over the next few hours, I would power up the system and test several times, resulting in different symptoms.
- Sometimes, everything would work perfectly from the remote or joystick
- Other times, the issue would reverse from bow thruster not working to stern thruster not working, however there would always be one or the other working whilst the other wasn't.
- At one point when I powered everything up, the bow thruster decided to start thrusting continuously of its own accord, however this time at a very low power, not really enough to push the bow, but enough to create a clonking / ticking sound from the motor, juddering and making small ripples in the water (confirming it was definitely the bow thruster). Whilst this was happening, the amber light on the joystick was flickering as well. It would continue to do this until I powered down from the breakers. Turning the remote control and joystick off did not stop this happening. Also, whilst this was happening, pushing the joystick to the left or right would momentarily stop the thruster juddering for a second or so, before it then started up again.
- Eventually after several hours, everything was working normal again every time I tested.
