big_s
Active Member
Hi all,
I have a 10kw motor powering a propeller via a 2.8:1 pulley gear and lay shaft. The lay shaft is mounted in a rigid frame using two simple flange bearings (ball bearings) and retaining collars. The lay shaft connects to the propeller shaft via an R&D flexible coupling. The 2 blade propeller has a diameter of 14" and a pitch of 10".
While this setup takes care of radial loads it doesnt consider axial loads. Do I need to introduce thrust bearings into the system and if so how?
I have only found one thread that considers the problem but the solution was described as non-ideal by the op; he used a load bearing and a thrust bearing for forward and reverse.
Others have suggested use of tapered roller bearings but I cant find any that are housed.
My initial thought is to glass in a fixed plywood cross member in the bilge that the thrust bearings are attached to. This would then isolate all thrust from the electric motor frame itself, with thrust forces being passed directly to the hull.
Any advice or insight much appreciated. Links to actual products would also be a great help.
Many thanks.
Many thanks.
