Ian_Edwards
Hi
I've had consistent problems with sealing BSP screwed joints on 3/8 inch fittings.
I've had a combination of air leaking in and diesel leaking out, depending on where in the fuel line the fitting is, and the pump drawing the fuel out of the tank.
Part of the problem is getting the correct fitting. Where I can I use parallel threads and Dowty washers (washers with rubber seals attached). These work OK, but I've often finished up with a male tappered thread and a parallel female thread. These seem to be very difficult to seal, especially when trying to line up an elbow.
I've tried different jointing compounds, high temperature silicone and the sort of thing you use on an engine. But they all seem to leak eventually.
What do others suggest I try?
