Rob_Webb
How about this?
Like you I've also always been confused by this. Also agree with others that over-riding consideration is to reduce noise and wear.
But reading this made me think about about the issue in another way. Try this.....
Imagine boat sailing along slowly (say 3-4 kts) with engine off. If there was a pressure guage inserted into the thrust bearing of the prop shaft it would show negative pressure i.e. the movement of water would be trying to gently pull the prop and it's shaft back out through the hull. This represents high drag on the boat.
Now start engine and engage forward drive. If you increased to full power the pressure guage in the prop shaft would show positive thrust and the boat would accelerate.
But as you gradually increased power from neutral to full power the thrust in the prop shaft guage would pass through a neutral stage as it transitioned from negative thrust (when prop was trying to drag itself back out thru hull) to positve thrust (accelerating boat).
My thinking therefore tells me that regardless of why the prop is turning (engine or water flow) the drag is gradually reducing from a maximum (when the prop is stationary) to a minimum (when it's pushing the boat along). And so when under sail alone, if the prop is freewheeling (even slowly) due to water flow, then it has got less drag than when stationary.
So locking the shaft will slightly increase drag again.
Any sense?
Of course the simplest answer is just to get a folding/feathering prop. Then the whole problem goes away!
Any sense?
