This was posted on our marina forum yesterday.
Might be of interest on here.
Not as yet mike.No information on when tourist travel to Spain would be permitted?
They will be looking at the R numbers .No information on when tourist travel to Spain would be permitted?
The problem as been that there is no room left in the boat yard. I just wanted my anodes out of the water?Hopefully not as a surprise!
How much do they charge for putting new sticky tape on?The problem as been that there is no room left in the boat yard. I just wanted my anodes out of the water?
Gorilla tape is a boater’s best friend ??How much do they charge for putting new sticky tape on?
That is how you know the fresh water tank is full?List to port ?
Is their pressure washer not working? That will be a right bastard to clean when it’s dry and baked on.The problem as been that there is no room left in the boat yard. I just wanted my anodes out of the water?
Now theres no continuity via the electrolyte sea water salt solution connecting what the anodes are supposed to be protecting .The problem as been that there is no room left in the boat yard. I just wanted my anodes out of the water?
I’m sure they did straight awayIs their pressure washer not working? That will be a right bastard to clean when it’s dry and baked on.
I would normally have the engine serviced by now with new pencil anodes and the hull anti fouled and new anodes and the stainless steel all polishedNow theres no continuity via the electrolyte sea water salt solution connecting what the anodes are supposed to be protecting .
Assume the engines coolers are swimming in seawater if the master cocks are closed or partially full if open and semi drained off during the lift .
If the latter then let’s hope the water level in various coolers is above ( if any applicable?) any pencil anodes .If they are dangling in air that’s not good either .
The best thing is to replace anodes in a timely fashion and keep them in continuity via sea water with what ever they protect .
Suppose a diver could have switched them out for new with the boat in situ ?
A few days out for the annual in the general scheme is ok .
Is it on its annual or just out for the C19 indefinitely?
I struggle to imagine why there should be more or less sea water left inside any cooler depending on whether the boat is on the hard or not.Now theres no continuity via the electrolyte sea water salt solution connecting what the anodes are supposed to be protecting .
If the latter then let’s hope the water level in various coolers is above ( if any applicable?) any pencil anodes .If they are dangling in air that’s not good either.
Good point but the zinc(s) need the continuity of the sea water to work to complete the electrolytic circuit .Thus irrespective of drain down , partial or complete , planed or otherwise corrosion of cooler components is a real issue because inadvertently the circuit is broken .I struggle to imagine why there should be more or less sea water left inside any cooler depending on whether the boat is on the hard or not.
Did you ever come across a boat whose CACs or HEs were not above the w/line?
