boatmike
As fitted to many Moody 346 and 35s. Anyone know the make and rating of the standard alternator offhand???
er Don't understand the 'back in the 60s ' bit. This is a T80 built in 1992..........
But anything designed by, and designated as, 'BMC' was designed in the 60's.er Don't understand the 'back in the 60s ' bit. This is a T80 built in 1992..........
But the kit was designed in the 1960s.er Don't understand the 'back in the 60s ' bit. This is a T80 built in 1992..........
The T80 is basically a Mitsubishi K4 marinised by Thorneycroft.
The alternator is a standard Lucas A127, as fitted to numerous UK vehicles in the 1980s and 1990s. It's rated at 70Amps, although you can get an uprated "narrowboat" version at 120Amp.
They can be sourced new at around £70, far better value than alternators supplied by other marine engines![]()
No, probably mid 80s. Modern Mitsubishi NOT 1950/60s BMC B series.But the kit was designed in the 1960s.
My bad. I blame google and only reading the first header I saw rather than clicking on it and seeing 1.5 mentioned ?.Don't understand the 'back in the 60s ' bit. This is a T80 built in 1992.
Thanks for that Moltini. Thats what I wanted, TaThe T80 is basically a Mitsubishi K4 marinised by Thorneycroft.
As it happens I have one for sale which came off a 50 Hp Thornycroft BMC Diesel.As fitted to many Moody 346 and 35s. Anyone know the make and rating of the standard alternator offhand???
