Bav34
My Bavaria has just made it to its 11th birthday still intact.
I was however concerned to read this survey:
There is some wear and tear to the gelcoat after 11 years use but generally the boat looks good and, with the exception of a couple of notable faults, is in fair condition. Unfortunately at least one of these, the backstay chainplate, requires immediate attention and the boat should not be sailed until this is repaired
The shroud chainplates are U bolts with the load carried to a moulding on the hull for the cap shrouds and spread with a backing pad for the lower shrouds.
The U bolts were tested as there was cracking to the gelcoat in way of the forward lower to port Photos 18 & 19 and also, to a lesser extent, to the aft lower to starboard. there was also some minor distortion to the deck noted in way of some of the U bolts although, oddly enough, not where the cracking was evident. I have seen this before in these boats and feel the chainplates could do with being stronger
Below deck the lowers could not be examined as they were hidden by linings but there were signs of water penetration at the cap shroud to starboard. Photo 20 There was also evidence that the forward lowers may have been leaking as there was excess sealant in way of the backing plates. Photo 21 Where water is in contact with stainless steel in the absence of oxygen, pitting and crevice corrosion can occur. It is quite common to find this on the shanks of U bolts, particularly when in use as chainplates. I would recommend that all shroud U bolts are withdrawn and examined. The Forestay U bolt should also be withdrawn and examined. See 2.6 The backstay is carried on a metal bar which is bolted to a moulding in the lazarette. This has not been well sealed and water has been leaking down the bar and there has been corrosion at the fastenings to the extent that the uppermost nut broke off in my hand. Photos 22 &23 The yacht must not be used under sail until this is replac
The lazarette was inspected and the laminate in good condition. However, there was extensive rust staining coming from the starboard quarter at the hull deck join. Photos 25 & 26. This is very difficult to examine and I cannot be certain of the exact source. It requires further investigation and could be quite difficult to repair
3.4 There are three Blakes seacocks fitted below the toilet. Two are the inlet and outlet for the toilet and the third is for a sink drain but the hose is blocked and no sink installed. They were all free to operate but there are a number of factors in the installation that are not in accordance with best practice. They are not fitted to mounting pads and are all only fitted with single hoseclips. The outlet hose exits in a straight run through the plinth supporting the toilet but the other two have a very tight bend. To accommodate this a short length of unreinforced, and therefore more flexible, hose has been fitted to the hose tail of the seacock and a copper elbow, which appears to be smooth bore, not a proper hose tail fitting, fitted. This leads to the sanitation hose. This gives multiple joints, the wrong type of hose, the wrong type of pipe, in addition to the other issues already mentioned. Photo 29. The problem is the very limited space in which they are installed mean that remedying any of these faults is impossible.
It's not all bad news though.
This survey was on a Contessa 32.
Hi AWOL ... see you fascination with Bavarias continues.
Mmmmmmmm, I really can see why. Don't feel bad about it.
