rafiki_
Do not attempt to turn the engine in gear from the propeller coupling, this will try and turn the engine through the gearbox and this is a bad idea.
Take the starter off, take the gearbox off, check the oil, pull the injectors. Try to turn the engine using the crankshaft nut - you may need to hire a 1" drive socket set with a large enough socket to do this. If it still won't turn over by hand in this state it is stuffed and is truly seized. In this case you may be able to hire or borrow a borescope to look inside the cylinders through the injector holes and see if any are scored or scuffed up, which will give you a clue what is going on.
If the engine still does not turn over on a good starter but can be turned by hand, it is possible that the main bearings are so worn that the crankshaft and/or pistons, even the flywheel are jamming when the starter ring gear engages, but this is unlikely as an engine that far gone would have practically no oil pressure and be noisy as f@ck when running. My money is on the gearbox but if you do the tests I have proposed you will find out what the problem is and do no further damage in the process.
I'm interested in your thought process, but surely smoke from the rocker gasket and dipstick tube are more indicative of an engine issue than transmission?
