Thininng out sikaflex?
Seagreen
30 Jul 2005
Tied up away from the storm. Oh yes.
As temporary solution I'd like to try thinning out sikaflex (or other similar compound) to get it to flow into smaller cracks. This is a temp fix to prolong the need to re-caulk a deck. Does anyone have experience with a similar issue?
Woodlouse
7 Jan 2006
Behind your curtains.
I can't imagine it would be even a mid term success. If you only have leaks in areas you'd be best raking out the sika there and doing local repairs. If the whole lot leaks then you don't have a lot of options.
Instead of trying to thin Sikaflex, what about pitch? Melt it in a bucket and pour it on, it would go some way to filling smaller cracks, but wouldn't be pretty.
Bobobolinsky
23 Feb 2007
Cambridge Fens
CT1 is expensive though, more than 291 I think I would rake out and do a local repair. It will give the timber time to dry out a little. Just trapping water under the caulk is storing up (more expensive) problems for a later date.
