davidej
For nav geeks and others interested in angles without a protractor see here:
Just remember that one radian is approximately 57 degrees (180/pi) and making you own protractor would be a dooddle.
Doesn't moss grow on the North side of trees?![]()
I believe that this isn't the best way of indicating north (in our hemisphere).
If the sun moves across the sky from left to right you are in the N hemisphere, or if from right to left, in the S hemisphere.
This has got me confused![]()
Silly question time.
If I know the time (UT) and date and have a sextant, can I
(a) work out my longitude by measuring the angle of the sun and detecting local midday when it is at its highest point
(b) then estimate my latitude by taking the angle and adjusting it for the time of year.
Is this remotely feasible and how accurate could it be using no tables.
To get any reasonable accuracy you would need to take account of the "Equation of Time". I think my sextant has a table for this stuck to the inside of the lid so if you have the sextant and it's case you can do pretty well without the tables.Silly question time.
But without taking account of the "Equation of Time" you could be 20 mins out - or 5 degrees of longitudeThe first bit is resonably accurate; it is the traditional way of computing longitude using a noon site. Problem is in determining the exact moment of maximum altitude of the Sun. Easier to do the meridian passage by equal altitudes (note the time when you take an altitude of the sun an hour or so before midday, then the time when it reaches the same altitude in the afternoon, and then the meridian passage is midway between the two)
Imagine waking up on a palm tree lined beach gentle breeze on a small island with no previous knowledge of how you got there.
How do you find out where you are ie North or South Hemisphere, what Lat and Long approx. What continent you are on or near, what the time is. What methods would you use to acertain where you are. Come on all you No.6's do your stuff or the big bubble will come and get you.
Please show all working out !!
(was hell of an Xmas do !)
Nigel
It was meant as a joke. However, it was taken from a comedy radio series, of someone in a similar situation; perhaps actually on a boat! I can't remember what it was though.I believe that this [tree moss] isn't the best way of indicating north (in our hemisphere).
You can get time from a lunar distance measurement to within about 15-30 seconds if you know the approximate date (to within a week or so). 15 second precision needs the measurement of the lunar distance to within 0'.1 and a very accurate almanac. Both of these requirements are tricky, but not impossible, to satisfy.
With approximate time you can get latitude from two (simultaneous) altitudes (this gives two solutions for latitude, but a later repeat of the process will resolve it to one)
With latitude you can get longitude from one time sight (same comment re: two solutions).
