sjohn_gibson
Earlier in the year on this forum I sought advice about mounting an Air Marine wind generator that I had recently purchased. I was hit with a number of critical replies pointing out my poor choice of wind generator – its noise – with only one constructive reply about the mounting issue.
After 2 months of use I thought it appropriate to update the forum on my experiences to date.
I mounted the generator at the top of mizzen. When it is charging there is a low but not intrusive swish noise - it is not distracting or annoying. When the batteries are fully charged, or if blade speed becomes excessive (strong gusts), the integral controller applies a brake (electrically). When braked the blades rotate slowly and are silent. In addition, I can select the brake on and the generator falls silent. I use this facility when anchored/moored near other boats, just in case there is down wind noise that I am not subjected to. When under sail I can’t hear the swish noise.
I accept that there may have been a noise problem with the earlier Air Marine models but it does not apply to the AirX model which has, in my opinion, successfully addressed the noise problem.
Best of all I have had the fridge, instruments + auto pilot “ON” and the generator (12-15 kts of wind) has maintained full charge in the batteries, often cutting out in the process.
I am delighted with its performance. If you would like any advice on how I mounted it just drop me a PM.
