maby
So where can I get that from, and can I take my boat there to fill up?
As I said above, you cannot, but that is not the government's fault....
So why would you want to fill up with Low sulphur road fuel. This has FAME in it and is known not to be suitable for marine use. ...
So it is almost impossible for you NOT to use Red Diesel.
The Irish farmer boys thought that was a good idea, false tanks etc, BUT the reveners arent soft, they take the sample from the bleed points on the engine, saw it on one of those cop shows!How is a tank dipped;- through the fill hose?
If so, all we need is a closed end tube full of the white stuff, carefully inserted inside the hose reaching the bottom of the tank.![]()
Actually they don't try to interfere with us in the UK, only when we break the law in their country.Charles, it is not about a God-given right of yachties, or being 'in-step' with anyone else, but a right of the UK to self determine what we can and cannot do here, without interference or approval of the Belgians or any other foreigner for that matter.
I would have thought receipts for red fuel purchased in the UK should be sufficient for those whose national affairs decree white, just how much more are we going to take of this officious nonsense from whatever source.
I'm afraid you're incorrect in fact, Chris.So why would you want to fill up with Low sulphur road fuel. This has FAME in it and is known not to be suitable for marine use. The Red diesel supplied to marinas in sea going areas is FAME free. In Greece we have no alternative but to use WHite diesel with up to 10% FAME in it. I have had to empty the tank at the end of the season to avoid the problems of wax sludge. I suspect Greek fuels are also of extremely variable quality!
Most road diesel contains up to 8% biodiesel (it's due to be higher in France this year).
On some very old mechanical injectors, wear increases without high sulphur content, equally high sulphur diesels produce greater acidic products of combustion, requiring more frequent oil changes.
Worst of all, for injector wear, is using 23 degree kerosene.
There is some evidence and a body of opinion which connects increased bacterial infection with high levels of biodiesel, in the presence of sunlight and temperatures exceeding 28C (unlikely in UK). It is probable that the source of the biodiesel is the determinant factor.
To go to Belgium and not get fined! Which is the point of this thread.
Would never sign up to a club that was so disadvantageous, and we do have a derogation to use red anyway, so not rule breaking.
Suggest you read the extensive material in the public domain, particularly on the RYA site.
You will see that the government IS vigorously defending its position on the matter, believing that its interpretation of the Directive into law is correct (or rather complies with the Directive, as the Commission has confirmed previously).
That does not of course necessarily mean they will be successful - whatever success is!
I refer you back to my question:
" our government is not defending its citizens abroad.
PWG
You (again) miss the point - our government is not defending its citizens abroad. Referring folks to the RYA site is somewhat less useful than pressing the government to do its prime job.
PWG
Are they also going to arrest and fine commercial vessels from the UK. Or what about lifeboats will the RNLI be fined for landing Belgian survivors in a Belgian port.
