Swanrad2
I love that video.
Thanks for the generous offer of pistons and the like - I hope, and I mean REALLY hope I don't have to take you up on them!
I love that video.
Wonder how long it took to clean up the camera afterwards?
When I rebuilt my Volvo MD2B (right down to crankshaft) I had serious problems getting oil pressure.
I had heard of engines seizing on first start up so I put an oil pressure gauge on where the oil pressure switch was located and cranked the engine by hand with the de-compressors open but could not get any oil pressure.
Then tried with the oil pressure gauge removed to give an open end to the oil circuit but still no oil flow out of the open connection point
Next tried the same using the electric starter but still no oil flow
Basically the problem is that the as the oil pump is driven off the end of the camshaft and as such, is above the oil level it has to create a partial vacuum in order to suck the oil from the sump.
One reason for loss of oil pressure on these engines is that the dipstick has to make a vacuum seal on the tube which goes down into the sump but that was ok.
Determined not to start the engine until I was 100% sure there was oil getting to the bearings, I connected a small vacuum pump to the oil pressure gauge point and ran the vacuum pump. I soon saw oil being sucked through the clear vacuum hose towards the pump so stopped the pump and opened up the pipe and turned the engine to see oil spurting out the hole.
Put the oil pressure gauge back on and could see the oil pressure rise.
I am sure in my case, the problem was down to a worn oil pump ( which to my shame, I had not paid too much attention to) so it did not self prime.
It could be argued that if I had just started the engine, the much higher speed would have primed the pump but there are no prizes for seizing an engine
If you have the same problem (and do not have access to a vacuum pump) you could remove the oil pump cover plate (behind the flywheel) and make sure the mechanism is well oiled so that it will prime.
Good luck for the weekend
Re Jcorstorphine
Interesting. I couldn't tell you where the oil pump is on the smaller Yanmars, but when ever I start the engine from cold , I spin it decompressed until the oil warning buzzer goes silent. Then do a standard start.
Some engines fire almost immediately -too immediately perhaps when left unused for a while..?
I am perhaps lucky in the exhaust ' hi rise ' allows quite a lot of cranking before I fear the dreaded HYDROLOCKING . It is still a good idea of course, though tedious, to almost shut the water inlet ( and re-open ho ho...)
So much to think about .... Might procrastinate for a week or two.
And better still? - Turning the water inlet off after letting it flow briefly, so that the water pump impellor is not running completely dry.
Leave the filters off then you can block the intake which will stop it, a fire extinguisher fired into the intake will stop it as a last resort.
Turning fuel off will not stop the engine in time!
nitrile washerI went to do it this weekend, when refitting the deck furl filler cap I had re-used the old rubber seal to the deck. Thing failed so had to be siliconed in as the tank had water in it! Arghhh, 2 hour drive there, two hour drive back - ages getting the process perfected on here, thwarted by re-using a bit rather than using 50p of silicone.
Next weekend!
Yes don't use silicone near diesel or petrol.It'll desintegrate.nitrile washer
