Quandary
In a recent thread someone was advocating using two anchors in tandem. Idly thinking about it this afternoon while polishing some bits, it occurred to me that though I have always carried two anchors, I have never tried using them in that way. In fact, I think I have only ever had both out once or twice. I anticipate that if it was ever necessary it would be in pretty grim conditions so it would be worth knowing how to do it as it seems very vulnerable to a foul up, and if that happens with both anchor already out the trouble could be major. I recall seeing diagrams for the practice which seemed a bit theoretical.
Anyone used this method routinely? I presume you put your best anchor out first, but this is generally the one with the best and longest chain, or do you switch the shorter chain on to the heavy anchor? Is the second anchor connected directly to the end of the first chain or is the first chain joined some distance back from the anchor on the second chain. If the first chain is attached directly to the second anchor I presume that anchor is simply acting as an anchor weight as it would be dragged about as the boat swings, but alternatively, if the two chains are joined behind the anchor is there an optimum distance to avoid a foul up, and how do you prevent the chains tangling with the anchor as the boat swings?
Is tandem anchoring a sensible idea at all? Or am I better with my former technique of laying the two anchors at about 30 degrees apart and adjusting scope as if the wind swings? Or perhaps the sensible man keeps his second anchor aboard until the first one is definitely dragging and then uses it as a last resort or should we just stay in a cosy marina.
