Asm
Doesn't this completely depend on which specific boat manufacturer and model you're referring to?
Princess - 52 56 60 64
Ok, so they realized that 750kg is not enough.Met with management at the PYI Factory Office today and sympathetic response to the problem was evident. However they need more time to research either the engineering solution to get the platform lower or resort to Ballast which is now looking more like a couple of Tons, subject to tests and trials, placed strategically to bring the whole vessel down to DWL not just the stern. I await the deliberations followed by their decision on suggested remedy.
You posted this while I was writing my previous reply.They say it is within specifications, nothing I am assured is missing.
Naaaaaaah, c'mon, jfm.Haha, get you MapisM! You ran away crying from the other thread about curved fins when the kitchen got a bit hot (even though you turned the heaters on) but hey when a fresh opportunity comes along to lob in an unfounded criticism of someone's innovation you cannot resist!
Sleipner's vector fins won the overall DAME award this year, by the way. And they are not fitted by Princess to the 56 afaik - that was a custom install done on the 56 built for the family that owns Sleipner
So its not a Med spec boat? No upgraded gennie, no pasarelle and as you say, no aircon or washer/dryer. Got to be over 1t of weight there. My guess would be that some numpty in the Princess design dept has done the platform design based on a Med spec boat and forgotten about lighter spec boats for the N European marketThey say it is within specifications, nothing I am assured is missing. The boat has aft cabin fit out, and holding tank. It does not however have A/C, Washer Dryer, Teak Side Decks / Fly Bridge. The six man Life Raft is not on Board at the moment. There is also extra Anchor Chain in the bow locker which does lift the stern marginally.
Well, considering also what Lozzer said of his P85, I'd rather think that at Princess they just underestimate the depth required for a lifting platform to work properly.My guess would be that some numpty in the Princess design dept has done the platform design based on a Med spec boat and forgotten about lighter spec boats for the N European market
higher excursion
That's a funny literal translation, an "excursion" is what old people go on a bus!
You mean "greater travel" or "range".
Hey Pete, while it goes against my better judgement both to disagree with youand to agree with Mapism
in fact I do think that the use of the word 'excursion' is correct in the context quoted. Pedantically you might say 'greater excursion' rather than 'higher excursion', but nevertheless in this context 'excursion' meaning 'range of travel' is correct, imho.
Apropos, I take it that you speak IT, petem?
A good one anyway, the IT for excursion is in fact "escursione".No sadly not, just a guess!
There's no getting away from the maths. MapisM is completely correct here. 2 tonnes evenly distributed will lower the boat something like 30mm, which is just not enough. This platform needs to go 200mm lower than it currently does, and that btw will need double-figures tonnes of ballast. Best to open all the floor hatches and pour in a truck load of ready-mixed concrete then...Ok, so they realized that 750kg is not enough.
It's reassuring that it didn't take them much longer than the 5 minutes which were necessary to a stupid forum poster who never designed boats for a living (that's me) to reach the same conclusion... :ambivalence:
And now, by how much would those 2T increase the draft of the whole vessel, according to them?
My estimate (note that I'm not calling this a guess anymore, as I did for the weight of the bare hull) is just a hair more than one inch. Whoa!
Regardless, I would explain them in not unclear terms that the only two realistic alternatives are either an "engineering solution to get the platform lower" or a full refund for a product not fit for purpose.
The 2T ballast suggestion (also accepting that it would be sufficient, and I very much doubt it), is something they should be ashamed to have even just mentioned.
If it were my boat, I would have suggested them a more straightforward use for such ballast: something which simply involves shoving, rather than "strategically placing"...![]()
Tee hee! No worries re kitchensIn fact, you are now telling us that Princess does not fit Sleipner stabs on her, and they only made one on request of Sleipner owners.
How weird is that, after the P56 was the only boat mentioned in that thread, where you said in the OP "The first ones are already in a 2013 Princess 56", and Sleipner made a big deal of the P56 installation on their brochure, including pics?
Petem, yup MapisM is correct in using "excursion". It is reasonably widely used in engineering terms as a version of "stroke" but with a slightly continental flavour![]()
