Nick_H
Since the full to empty difference is about 3T
Fuel difference < 2 tonnes I'd have thought, allowing for 2650 litre tankage, reserve, and specific gravity of diesel.
If I read the Princess reply correctly, they are saying that the OP's boat has a minimum depth over the fully lowered platform of 362mm (ie. at low fuel levels). Jimmy informs us that the Williams has a draft of 300mm max. If both those are correct, then is it just the chocks that get in the way? If so, the easiest solution must be to design some very thin chocks?....QUOTE]
in order to follow the profile of the Williams I doubt the chocks could be much lower than 40mm, this would only allow 22mm of clearance, fine in dead calm conditions but with any kind of chop the same problem arises.
I've not had a hi-lo platform, but I guess you pull the tender on from the side, bow first, so you don't need to clear the full height of the chocks, only the lowest point. Even if this isn't normally required, it may be a solution for the OP. I suspect the issue is deeper than this though, or should I say shallower.
Wey hey Jimmy, even though I am 'old' thats my kind of ballastGreat thinking Mike. You can see that this owner has a similar prob trying to get his bathing platform to stay underwater, and in line with your suggestion has rejected ballast in favour of 'something useful'...
Well, I didn't consider any reserve, since I guessed the 83mm they quoted was a theorical number based on the dry vs. full load difference. Besides, I included the fresh water tank.Fuel difference < 2 tonnes I'd have thought, allowing for 2650 litre tankage, reserve, and specific gravity of diesel.
I suspect what we're talking about here is a bit of a cock up in the design dept, rather than an inherent hull issue, in that the designers have calculated the position of the platform based on a certain spec of boat. Put this together with a platform that has quite a limited range of movement and then you may have a problem with fully submerging the platform on a lightly specced boat. It would be interesting to know what the spec of the OP's boat is and where it is based (UK or Med). Does he have aircon, pasarelle, crew cabin and other weighty equipment or not? Does he have the standard gennie or upgraded one?To start with, a boat weighing less than 25T dry, according to the builder specs.
And they are suggesting that a 750kg ballast astern would bring the stern draft of your specific boat "back to normal", so to speak.
Now, forget the effect on performance. The first thought is that there isn't much else other than the main GRP shells, where that weight might have been lost.
But it is difficult to know (I mean, without some inside knowledge - the builder must know exactly, of course), the weight of the bare hull and superstructure.
+1.I suspect what we're talking about here is a bit of a cock up in the design dept, rather than an inherent hull issue
Wey hey Jimmy, even though I am 'old' thats my kind of ballast![]()
I have the .dwg files here for the HB Technics lift system but can't open them on this office computer. Can do tonight at home. But flick to 5:08 in the vid below of my previous boat. Actually that is the still already showing in the freeze frame below - you do not need to play the vid. That is platform down. The vertical stroke of the platform is about a metre and the level of the teak below waterline when platform is down is 800mm or soSo what would a typical bathing platform drop be? Actual measurements rather than guesses please.
Haha, get you MapisM! You ran away crying from the other thread about curved fins when the kitchen got a bit hot (even though you turned the heaters on) but hey when a fresh opportunity comes along to lob in an unfounded criticism of someone's innovation you cannot resist!ROTFL, I suppose that "whatever" includes a notorious curved equipment.
So, eventually we are understanding why it was chosen for the P56.
Nothing to see with vectorial analysis, 'twas all down to someone in Plymouth saving a few quids...!
Sorry jfm, but I REALLY couldn't resist this one.....![]()
So what is a normal or recommended drop ?
More and more boats seem to be fitted with moving platforms or variations so I think it would be a useful thing to know.
I presume there is an added complication with movable platforms in that you don't want them too close to the water when up and closed otherwise the platform acts as part of the hull or a giant trim tab when underway, particularly when it is a nice deep platform. If in contact with the water a lot of stress will be placed on it as it supports the vessel.
Henry
Never having been in the fortunate position of specifying a new boat with a hi/lo platform, what do boatbuilders sell these things as? Do they sell them specifically as tender launching systems or as get yer feet wet paddling pool extensions? I'm just wondering if Princess might turn around and claim to the OP that they never sold it as a tender launch system. Also is there not the option to lift the tender in with the pasarelle on some boats as well as the hi/lo system?This is a Princess mistake alas. They have saved cost by buying an inferior lift system that has too little vertical stroke
See post #40.
At the MBY 40-foot sea trial day last year I was on the Princess V42, which also had a hi-lo platform. The salesman from PMYS did say that in that case the platform had a lifting capacity of just 100kg and was not intended as a tender lift (the V42 does have a tender garage, so this does make sense).
I asked if were possible to specify a passerell that could lift a rib onto a fixed platform. No! was the answer ( a transom glass panel fitted to a lot of current models prevents it ) unless you wished to push your rib over the platform to launch it, you had to order the lifting platform. For the Med you still have to spec a passerell, but it's off to one side and cannot lift. Apparently it's what boat owners want!
Been following this thread with interest.
I am from a displacement only background, I thought of barges and propellor immersion when empty.
Although the correct answer is a longer drop of the deck, would fast filling, and emptying ballast tank in lazarette be a sensible answer.
Would get the depth for rib launch without the weight penalty underway
