julians
You need to get hold of the detailed service invoice and see if the bellows were replaced recently or not
This week we have just had a pre purchase survey done on a 40’ sports cruiser and while nothing much was found it’s raised some serious doubt.
The boat is fitted with d4 300s and was 400 rpm down and about 5 knots.
Trim tabs not working and exhaust bellows need changing.
The doubt comes from the boat having engines and drives serviced in March along with anodes and anti foul now being a novice and current boat has outboards I had a Google of exhaust bellows and results came up as they need changing every 2. Years, if so would that not be done when the drives were serviced?
The broker put the loss of speed/revs down to weed but is it underpowered with the 300 s
Am I right to have doubt or am I being over concerned?
The broker arranged the sea trail boat lift and survey around when he could get the boat lifted.So let me get this straight.
You’ve had an out of the water survey and a sea trial?
Yet you did the sea trial first?
You should have had the out of water survey first and had it jet washed.
And the surveyor didn’t advise this or advise it could be responsible for the speed loss?
I’m surprised it’s only down by that amount if it’s not been out since March. It’s been a hot summer remember.
I’d be concerned about the surveyor rather than the boat.
Absolutely. Get another sea trial. That will put your mind at rest. Or not of course. But a boat under warrantee sounds good to me.The broker arranged the sea trail boat lift and survey around when he could get the boat lifted.
It would have made sense to have done the sea trail last.
You have not said what type or model of boat this is though I think I can guess.This week we have just had a pre purchase survey done on a 40’ sports cruiser and while nothing much was found it’s raised some serious doubt.
Had a Volvo engineer on board he said the lack of revs/speed was due to bring dirtyYou have not said what type or model of boat this is though I think I can guess.
2 xD4 300 is ridiculously small for a 40 ft boat that you are going to expect to perfo as it says in the sales brochure or what the broker claims in the speel.
400 rpm down is a high margin because it will reduce your cruise speed even further because you cannot use what it will attain which is 3100 , you will only be able to run it all day at 2900 which may place it at the spot where it’s trying to climb it’s own trough .
So did you have an engineer on board , I find surveyors know very little about engines and drives to give the correct advice, Im guessing no that’s why your on here .
Typical broker saying it’s weed when you must have carried out the sea tria, after it was lifted for hull and drive inspection .
Did he have the vodia plugged in to read the data and see what percentage load was on each engine in relation to throttle position to deduce it’s hull growth , was the sea trial after lift out ?Had a Volvo engineer on board he said the lack of revs/speed was due to bring dirty
Sea trail was after lift out he plugged into one engine took the data from a run then plugged into the other on the way back, everything was reading as it should just not making WOTDid he have the vodia plugged in to read the data and see what percentage load was on each engine in relation to throttle position to deduce it’s hull growth , was the sea trial after lift out ?
I am putting the effort in drove 250 miles none stop to make the last trail, I will see if a re run can be arranged for when Ican make it down again ?Well I would be there for the sea trial, you could drive , you will know the sea state and the big one , if you like it . Ps put some effort in it’s a lot of money.
