alexhibbert
Active Member
Hi all, I wonder if an electrics expert could help.
I have designed and installed my boat's electric system, which mostly supplies power for engine start, lighting, external cameras, and ducting fans. Everything so far has worked first time (probably more luck than judgement!). Until now.
The batteries supply 24V, to be used by 24V hardware, or regulated down to 12V for those items that need it.
I have three sets of LED strip lights - at 12V. For the first two, I step the voltage down to 12V (a Victron unit each) and then each have a dimmer switch. They work fine - the LEDs are getting 12.3V at the top end, and smoothly dim until cutout at 5V.
The problem is that the third, although as far as I can see wired the same, won't dim. The switch appears to have no effect at all, and even when the dimmer says OFF, the full 12V are passing though. I thought the dimmer might be busted, but I swapped in one of the others and the same happens. That trial dimmer continued to work fine when put back into its own circuit, so the dimmers aren't being actively broken by an action of mine.
I wondered if it was only this sort of dimmer. As I was installing a ducting fan with an inline dimmer switch (not the same model or brand as the LED one), the same thing. All the connections are made carefully, but the full voltage passes through and ignores the dimmer. These are 24V fans and the dimmer is rated to both 12 and 24V.
Any ideas why the dimmers are being 'ignored'? I imagined if I'd busted them with a mistake or a short that they would stop working entirely?
