Brent Swain
N/A
Definition;
Anecdote
Reality and experience which contradicts and disproves one's pet theory.
Anecdote
No, exacerbation is the right word to describe it.
Don't tell me you print your own dictionaries as well.
My Harken blocks are more than man enough for their job, which is what matters, not inferior weak crap as you say.
The trolls are those who only came on this forum after I became active here, and respond mainly to my posts.
I don't have all my drawings in digital form, but will send the ones I have, and photos.
Bob Perry and Smackdaddy, who has been quoting himself here, are my main attackers attacking every single post I have made , on some sites.
For inside welding and painting, I have found it easier to breath air thru 24 feet of 1 1/4 inch plastic sump drain hose than thru a filtre, and the hose doesn't plug up. Some have attached it to a surplus gas mask or a standard mask without the filtre. Put the end up wind, and you have zero chance of breathing any fumes. No need to force the air in, not any benefit in doing so.
Mmm. Assuming 1.25 inches is the internal diameter of Brent's 24ft hose, the volume is approximately 5.881 litres:I don’t mean to hound you but if you breathe through a long pipe/hose in the way you suggest you’d die. Actually the urge to rip the mask off would be too strong and you’d gasp for fresh air and probably wouldn’t die.
Doing what you suggest would mean that you’d be rebreathing your own exhaled air. I’ll let someone else explain.
https://www.quora.com/Whats-the-lon...er-hose-a-person-could-breath-through-on-land
I wish I'd seen this before I did the sums.:ambivalence:Most masks, including gas masks have a one way valve in them, so the air can only flow one direction.
I should really wait for Brent to explain gently to you what he meant. I would think it highly unlikely that he is suggesting breathing both in and out through his tube. Do you think that Scuba divers breathe out back into their air bottles?
Maybe you were just being deliberately argumentative?
I’m usually quick to apologise but I need to point out that in this instance no apology was intended."Perhaps a case of being a little more explicit and ensuring you write what you mean to say unambiguously."
It's not much of an apology, but I'm afraid it's the closest you'll get on here Brent!
In this instance I think an apology was deserved though.
The guy is bombastic in his writing style, yet he has undoubtedly built a number of steel boats and doing this without spending vast amounts (relatively speaking). Personally I don't think his understanding of welding chemistry is up to much, but what he has done has worked. To be honest if I had the money for a liferaft there are plenty of other things that I'd spend it on beforehand.
He has wound you up no doubt, but now you're jumping on everything he says and it starts to look personal.
When he said about using a long tube for an air supply, you stated that it wouldn't work. I don't think that you thought through the physics and made assumptions, and got it wrong. Since we know that he actually has done the things he claims (to a greater or lesser extent) then in effect you were calling him a liar.
The day that sweeping statements go unchallenged on these forums will be when ....People read these forums who are looking for inspiration and I don’t think it’s responsible to allow sweeping statements that are wrong and sometimes dangerous to go unchallenged.
I don't know much about Brent. I had never even heard of the guy until a few days ago when this thread had already exceded 40 pages.
Just my impression from this thread and having used google.
Brent is a guy. Kind of like your local handy man, who designed and builds steel boats. For the backyard handy man to build by him or her self. For a low back yard cost.
The boats are of a very simple design. Cut from a single relatively heavy piece of fairly thick mild steel plate.
They have a few longitudinal frames.
The chine adds longitudinal strength.
4500 lbs of lead inside a fairly long steel keel.
A skeg and transom hung rudder.
Displacement 20 000lbs give or take.
They look quite nice.
I don't think the boats are intended to be approved and coded by the MCA, EU, Lloyds, ABS or even TC.
I not a naval architect. Even so my rough guess. The boats are built like brick shit house. Only out of steel.
My GRP 35ft IOR has about the same sise keel and a displacement of about 10500Lbs
My boat is wider, stiffer, lighter, faster. but not as tough.
My rough guess a Brent Swain 36ft boats center of Gravity G is a little bit higher than my C&C 35. Not a lot higher most of the weight is still in the steel hull and keel.
A BS 36 has a fuller deeper hull than my C&C 35.
My rough guess the center of Buoyacy B is a bit lower than my C&C 35
I happened to find a copy of T Cunclifs complete YM book in a 2nd hand book store a couple of days ago 4th edition from 2003.
His stability diagram is almost but not quite right. Its a B not a Z. He may have corrected the typo in later editions. ( 5 bucks, its actualy quite a good book)
If were to do an inclining experiment on a BS boat I could figure out a reasonably estimate of the GM. (M is the metacentric height an imaginary position on the centerline where a verticle line drawn up though B cross the centerline If the vessel is slightly inclined)
B moves to the low side when the vessel is inclined.
And slightly down
So long as M remains above G the boat will remain stable and have a positive righting lever.
If G and M are in the same place stability will be neutral.
If M goes below G it will become unstable.
So My uneducated guessing. based on some simple principles. The lower B will offset some of the disadvantages of the slightly higher G
and The GM of a BS 36 will only a reasonable amount less than my C&C 35.
So my uneducated non naval architects guess. A BS 36 is fairly stable sailing vessel with a stability range comparable to other long keel heavy built blue water type traditional sailing vessels
So my conclusions.
A BS 36 is built like a brick shit house, pretty stable, and probably sails pretty much like any other long keel heavy cruising vessel.
Who needs a naval architect?
PS. I would not use a home made block to lift anything. Unless they get tested and come with a # & certificate.
Mind you Harken blocks don't have # & certificate. Best not lift anything with a harken block.
As long as BS is not lifting stuff with his homemade blocks I don't think he is breaking any WCB or H&S rules on his sailboat.
All very reasonable.
But you don't go about saying everyone else is wrong and you're right and go on to make spurious claims about how to firefight, how brilliantly your boats sail (they defy the laws of physics if they do) how stupid everyone else is to sail around on GRP boats, how your boat can't possibly sink, your welds never fail, beginners welds never fail, you only need to do a couple of hours of maintenance a year and the paint looks as good as when you applied it twenty years ago etc etc.
I think Brent probably has some really useful things to say, but while he carries on making wildly silly assertions that are so obviously false, and then lashing out at people who point this out, he's not going to be taken seriously.
I agree.
I get the impression. When he gets challenged about his boats he over reacts and says things which are easy to discredit. which is also unfortunate.
