Wansworth
Can be confusing in an anchorage thinking the light is at the bows and it’s errr……notSo not on the stern arch?
Yes, I thought about that too… Would be more convenient for mounting and cable thoughCan be confusing in an anchorage thinking the light is at the bows and it’s errr……not
As the general objective is to anchor in shelter, so in most cases boats will anchor lying bows to the shore and stern to the entrance / sea. Hence approaching boats generally much more likely to be approaching from astern. Hence under the boom is in fact usually better than ahead of the mast (and often easier to plug in).Yes they do, “forepart” but also states where they can best be seen. Larger vessels also in the stern, lower than forepart.
…. Hence under the boom is in fact usually better than ahead of the mast (and often easier to plug in).
Can you recommend any shops where you can find one of these polluting lamps?
And a handful of nails.pleaseYour handy local traditional style ironmongers.
Oh, hang on.![]()
So what about coming in across tide looking for a mooring spot or a mooring buoy? Normally one might expect boats moving up or down tide to be out in a fairway rather than in a mooring area- would they not?mmmm no tide / current effects then ? Surely boat is 50% facing out ... 50% facing in depending on tidal flow ?? or wind ...
Depends where you sail - presumably minimal / no tide in Baltic and Med, and also most anchorages I tend to use in Scotland in bays the tidal flow is not a big factor. Different perhaps for those who anchor in rivers rathet than bays.mmmm no tide / current effects then ? Surely boat is 50% facing out ... 50% facing in depending on tidal flow ?? or wind ...
Good article - not just because he seems to concur with my view and use a light below the boom / above the sprayhood.Article Anchor lights test
Forepart is specified for >50 meters. For the OP's boat ...Yes they do, “forepart” but also states where they can best be seen. Larger vessels also in the stern, lower than forepart.
I have an anchor light that can be hung from the forestay at a suitable height. Much easier to change the bulb.Thank you for the answers. I understand and will fix the anchorlight as soon as possible. Or add another one.
and stinks the place to high heaven.Yes but a litre can goes a long way…….andis very nautical![]()
Some people need to visit SpecSavers other, and some would argue better, opticians are available,Masthead is often the worst place for an anchor light - way out of line of sight for boats manoevering around an anchorage.
