Steam cleaning deck and topsides
doris
19 Jun 2001
London
A mate has offered to lend me his steam cleaning kit to sort out my deck and topsides. The plan is to brush on a load of detergent, leave it for half an hour and then steam clean the lot. Apparently it will come up like new. Are there any downsides to this procedure???
TheBoatman
12 Nov 2002
Kent
The biggest downside is that you might remove some of the gelcoat, it brings it up a bit like a sandpaper finish. It will be very clean but just be careful. I suggest you test a small area first.
robp
Yes, this was demonstrated beautifully with some plastic garden furniture that was greyed and rust stained. It was clean it or throw it, so my wife jet washed it close up and it came up lovely but with a new textured surface. It had removed the surface. It's really hard not to be brutal, so watch your gelcoat!
tcm
11 Jan 2002
Caribbean at the moment
Re: bad idea Steam cleaning deck and topsides
Even i think that this is a rubbish idea, and i'm a total lunatic when it comes to cleaning things as adventurously as possible. For example, i discovered that cleaning certain types of plastic awnings with petrol is brilliant if you're quick. I also discovered that cleaning PVC seats with neat bleach means that you need to replace the seats inclusing the foam, and buy new trousers and shorts for everyone who has ever been on the boat.
If you got a boiling kettle and placed it on the gelcoat - would it not leave a mark? I bet it would. The steam will be that hot. It would be ok to steam clean an engine, thou it would remove any loose paint (and it would also remove some of the not-so-loose paint)
I would (and do) use a commercial cleaning product at low concentrations to clean the gelcoat once every month or so maximum. Send a pm to a poster hereabouts "hlb" asking him to sell you some. dilute at least 1:20 parts with water, lightly brush it on, then rinse it off, then totally clean boat and no steam. If you don't dilute and use it on a fender, the fender goes yellow. If you do dilute, the fender looks brand new without any scrubbing.
orion21
22 Jan 2004
Orkney (scotland)
Hi all, If you want a great job with out to much hard work and look after your gelcoat try"wipeout". Its a powder that comes it a lrt bottle, you wet the surface sprinkle the powder over and brush it about a bit, leave it about 15 mins then just hose it off. I was well pleased with the result it was like new again. You can do the hull as well, i did and can't believe how good it looks.
Hope this is a help to you, Cheers Geordie
david_e
1 Oct 2001
www.touraine.blogspot.com
I thought it OK to powerwash plastic decks ( a la Bennytoe variety ) but obviously not the topsides as others mention, strips the gelcoat off.
tcm
11 Jan 2002
powerwashing is a waste of time relative to the magical powers of hlb's chemicals. I think powerwashing is a bit mechanical too, hammers away at the plastic. Ideal for rinsing the neighbours though.
doris
19 Jun 2001
London
OK then. If steam is a bad idea can anyone tell me which are the best chemicals to use. The deck is well grubby and it's boring the way peolple talk about theirs ....looking like new.
complete marine
22 Aug 2013
ok here it is!
Ok here it is . Pressure washers can be work well. It all depends on how powerful they are. If they are too much, lift the lance slightly. to reduce the pressure.
If you prefer a chemical approach. I can supply a easy to use boat wash solution that lifts dirt easily. This product with a simple pot of Milton fluid, yes that's right the baby bottle sanitizer work amazingly on non-slip deck!! and only £2 in the supermarket. :D
sailorman
21 May 2003
Here or thertemp ashore
power washers are a great invention.
For finding all gelcoat voids you didnt know you had
Pete7
11 Aug 2004
Gosport
OK then. If steam is a bad idea can anyone tell me which are the best chemicals to use. The deck is well grubby and it's boring the way peolple talk about theirs ....looking like new. <hr width=100% size=1>
Dhoby Dust (that's Daz washing powder for civies) lightly sprinkled on the deck before you go home and wait for the rain. Result nice clean decks next time you visit :)
Heckler
24 Feb 2003
Oxalix acid powder off ebay, follow the instructions, brings fi glass and wood up like new. Its the main ingredient in the expensive £14 a bottle chandlery stuff!
Stu
tommydortez
25 Apr 2014
The Deep Blue
thepowersite.co.uk
i just washed my decks with a powerwasher. bought a cheap petrol one and you can adjust the pressure with a nozel on the pump. saves messing about with chemicals and baby bottle sanitizer :)
