colind3782
My Sole Mini 34 needs up to a minute of preheat in the winter before starting. Not unusual according to the manual.
Because they snapped off due to corrosion (as is normally the case!)Eh?
Why do you need to remove the head to replace the heaters?
That's a misapprehension. The compression heat is dissipated immediately on the expansion stroke if the fuel doesn't burn. Having said that, I used to own a 2003 that needed a lot of turning over on an early season cold morning. It was probably accumulating fuel in the cylinders, increasing the compression ratio. Or there may have been partial combustion slowly warming it up.I keep it going because the compression heat is building up in the cylinders.
Thats an answer I was after. You reckon the heat inside isn't building up then eh?That's a misapprehension. The compression heat is dissipated immediately on the expansion stroke if the fuel doesn't burn. Having said that, I used to own a 2003 that needed a lot of turning over on an early season cold morning. It was probably accumulating fuel in the cylinders, increasing the compression ratio. Or there may have been partial combustion slowly warming it up.
They are a standard item. If you have a metal air filter then it should be possible to install there. You will also need a fuel feed from your engine filter and of course 12 colts thrpugh a switch to operate it.Thermostart sounds interesting. Any recommendation for a VP2003?
Even using the correct procedure, my VP2003 can take quite a few revolutions to start from dead cold, and this seems usual for the model. If it has been started on the same day, it starts pretty much instantly, but if left for more than 24 hours it needs longer.
In warmish weather diesel starting should be a doddle. If not, try a short spray of fine oil into the air intake - helps the valves to seal against their seatings. Failing that a shot of starter fluid. Long cranking episodes are wasteful and can crock the battery. When in trouble like this, turn off the seawater intake to save flooding the engine and make sure you turn back on immediately it fires.If you are cranking away, should you be keeping at it as you have heat building up in the cylinder, or it doesnt matter and you can wander off and come back and try some more?
Spray a little bit of "Easy Start" in the intake; it will start instantly.
I am intrigued.
Is this the part?
Amazon.com: Mover Part Thermostart Heater Plug AR63103 for John Deere 820 920 830 930 1030 1130 1630+: Automotive
In needs fuel as well as 12 volts does it? Sounds like a mini blow torch!
I am intrigued.
Is this the part?
So many people repeat the old wives tale of diesel engines becoming dependent on Ether (Easy Start) ... what a load of cobblers !!
Yes - I agree its an aggressive 'fuel' to start an engine - BUT that's WHY it works !!
Tractors ... trucks ... loads of boat engines ... generators ... over many years I've had to resort to Easy Start ... it has never done any harm ... all of them have survived without developing a need for it ...
An old trick if you didn't like Ether - was to use WD40 ... but that no longer works.
