Poignard
I like the sense of humour of whoever decided on the name!Got a can of that on our Kiwi boat.
I just had to buy one, even though it is not required.
These things don't always work quite as you expect.So many people repeat the old wives tale of diesel engines becoming dependent on Ether (Easy Start) ... what a load of cobblers !!
Yes - I agree its an aggressive 'fuel' to start an engine - BUT that's WHY it works !!
Tractors ... trucks ... loads of boat engines ... generators ... over many years I've had to resort to Easy Start ... it has never done any harm ... all of them have survived without developing a need for it ...
An old trick if you didn't like Ether - was to use WD40 ... but that no longer works.
They are a standard item. If you have a metal air filter then it should be possible to install there. You will also need a fuel feed from your engine filter and of course 12 colts thrpugh a switch to operate it.
You still haven't told why fitting a thermostat helps start a diesel. I am intrigued.If there is no cold start fitted, retro fitting a thermostart will transform starting. They can be fitted to any engine. I put one on a BMC 1.5 when I couldn't face taking the head off to replace the broken heater plugs.
ThermostaRt - It puzzled me for a moment too.You still haven't told why fitting a thermostat helps start a diesel. I am intrigued.
I fitted a 'bulb' fuel 'thingy' in line which appears to have negated the need for bleeding.I'm envious of people with self bleeding diesels. Mine is hell on earth to bleed, often taking a few attempts. Enough to put one right off changing fuel filters for the above reason.
I would suggest a stop cock in the fuel feed as these are notorious for leaking ... they are supposed to be a 'heat activated' valve in the body - but I know mine does not close.
I would also advise a separate fuel feed from a small medicine or pill container .....
I had a connection to fuel system when engine was changed ... I lost my old small reservior .... it was trouble because the glow plug feed did not shut off fully ...
I reverted to a separate small supply and all was good again.
I'll try reading the posts correctly in future - thermostart not thermostat!The Thermostart produces a flame that is drawn into the cylinders providing heat exactly where it is needed. Far more efficient than heater plugs.
Never had a leak on any of mine and no separate reservoir is required, that was a very old system that was found to be unnecessary.
Yes, that's it, basically a mini blow torch without the fierceness of the torch flame.. Fitted as standard on older Perkins, Bedford and others I can't remember!
Ooooeeeerrrr ..... I have my own pet stalker.Did you tickle it? I've heard recently that this is required.
Bedford 466 and 500 both had thermostarts.Bedford ? All Bedford TK's ... TM's I rode in had Cold Start levers - that basically bypassed the governor on the pumps and allowed larger volume of diesel to be injected ... no glow plugs or thermo's.
In fact Leyland Bedford ended up removing the pull lever from the cab and putting it outside under the rear of the cab same as Fords ... to stop drivers pulling it out to get up hills !!!
