Stainless machine screws stuck in aluminium
dgadee
13 Oct 2010
I am thinking about removing and replacing the genoa tracks before leaks develop. But some bits which I have removed from the boat already have had the odd bolt stuck in the aluminium (turning blocks, traveller). I would not want the hassle of bolts which don't want to come out. Did I see here some time ago someone using acid to free bolts? Or was that my imagination?
DownWest
25 Dec 2007
S.W. France
I just picked up one of those little gas torches that chiefs use to 'burn' the top of Crème Brulée It has a very sharp flame and it did occure that it might be good for heating small areas?
fredrussell
24 Mar 2015
As above. Freed off a very stubborn furler assembly for a friend recently. Only heat would do it. Trouble is, the bit you are heating up is right next to fibreglass if I understand correctly, so heat may not be an option. That said, once nuts all removed below deck, you should be able to lift track with stuck bolts in place and remove with heat then / or a tap with a hammer at that point.
dgadee
13 Oct 2010
No, the track will be off - usually nuts are easy to remove, it's the machine screw gets bonded to whatever it passes through. I had access to a press which got most out, but not all.
But was I wrong about acid being usable?
greeny
15 Jun 2004
Portugal
I removed the mainsheet traveller to fix leaks and found it was Fixed in place with a sikoflex type product. I couldn't get a cheese wire in to cut it and it finished up pulling areas of gelcoat non slip off with it. PIA to repair. Be careful.
rogerthebodger
3 Nov 2001
When I fitted my genoa tracks to my current boat it came with countersunk plastic washers to fit into the top of the track to insulate the stainless steel from the aluminum track.
No issue with corrosion
The only I found to remove stainless fittings in aluminum is heat, force or drill the bolt out
dgadee
13 Oct 2010
Nothing has been glued in place so far, so I hope the tracks are similar. I plan to use butyl rubber wrap around the bolts.
ashtead
17 Jun 2008
Surrey and Gosport UK
Another thought is boiling water if you can make a reservoir around offending parts -it might be simpler than acid?. When I had to remove some mainsheet traveler end blocks it worked to free stainless screws in track.
