JumbleDuck
Can anyone recommend a supplier of this stuff? I am looking for 6mm and 8mm ID.
I cut and pasted the thread title into ebay and it came up with 281 results.
That's the problem.
I've had a look at Demon Tweeks, and the stuff they sell is supposed to be used only with special end fittings. Is this the case for all the PTFE stuff?
PTFE is not very rubbery, so clamping it like rubber hoses is perhaps not going to work?
You can get AFAIK nitrile oil/fuel hose with an ss overbraid.
Any reason it has to be PTFE? Car builder solutions sell stainless braided fuel hose in both 6 and 8 mm bore in both standard and ethanol proof forms. https://www.carbuildersolutions.com/uk/stainless-fuel-hose
Any reason it has to be PTFE?...
And just to throw in another question - why braided? Braided means you can't check the condition of the rubber hose.
True. I'd rather have non-braided.
Confession time. It's not for my boat. It's for my Citroën DS and my Triumph Herald, both of which have in the recent past had their petrol hoses attacked by mice. In fact, I had to replace DS hoses three times before I went for stainless braided, since when the mice have had no effect and are presumably skulking, baffled, in their nests and making appointments with muscine dentists.
I have one more particularly inaccessible hose to do on the DS, and I also need to replace the steel pipe which runs right round the engine in the Herald, and it will be much easier to do that with something flexible.
Confession time. It's not for my boat. It's for my Citroën DS and my Triumph Herald, both of which have in the recent past had their petrol hoses attacked by mice...
Why don't people post their real intentions in the OP??
That might be a good reason to go braided. Or you could get a cat? If the mice can't get the fuel lines they might try the electrics.
