DTIM
31.75 for me!
Hi Bart,
Apologies if this has been covered, but I was once part of an interesting discussion concerning the positioning of stabs which included the fact that an incorrect position would casue the autopilot to fight stab corrections since stab movement would alter boat heading. Depending upon the sea state, it could become a nasty form of what I'd call Dutch Roll (flying term), or corkscrewing. Getting an architect to nail his colours on the correct position wojuld be something I'd do.
Again, apologies if this has already been mentioned.
Piers
Actually, there was an agreement, to some extent.fighting stab controll soft and autopilot, this topic has been well covered or discussed by Jfm and MapisM in another thread some months back, and iirc there was no formal agreement on that.
Yep, agreed, but that's in a totally different league compared to fin stabs.This is very valid. I had trim tabs with auto function on my previous boat and the autopilot was unusable when engaging the auto tab function. The systems would have needed to be integrated to work properly together.
LOL, how very true... And you've not yet heard of converting every alu parts to brand new shining chromed ones...!
Anyway, now that the measurement method is sorted, shall we make this thread really interesting with some bets?
My guess is a couple of inches.
Oi, that doesn't count. Otherwise, I could have safely said 50mm +/- 30mm!+/- 10mm.
Oi, that doesn't count. Otherwise, I could have safely said 50mm +/- 30mm!![]()
playing it safe, 32.5mm
Now, got to have a award for the nearest match, don't we?
V.
didn't mean THAT match rafiki!The only person who can award Match is JFM, and I'm not sure he will want to hand over his new toy just yet![]()
LOL, I just meant that ranges make the guess too easy.Scuse, non ho capito...................![]()
But the discussion was about whether having a joint control of the stabs and the rudders would have brought meaningful benefits.
My view was that such benefits, if any, could only be significant wherever the stabs are NOT actually doing a lot to stabilise the roll.
And in such conditions, they could as well be kept free floating, hence letting the fins self-center themselves along the ideal position at any speed, reducing in turn the system wear and also getting rid of the power absorption.
Incidentally, in the case of electric stabs, it's even more obvious that in a flat sea it's better to shut the whole thing down, in order to avoid using the genset.
IIRC, also jfm agreed that an integrated rudders+fins control can only be relevant when the fins are not working a lot.
What Piers says is a bit different.
In the debate with jfm, we always assumed that the fins were placed correctly, to start with.
I would agree with Piers that a wrong fins placement (i.e. too far from the boat CoG) could also affect the hull direction, rather than just its roll.
Otoh, I would think also that in order to introduce such unwanted consequence, the fins position must be AWFULLY wrong.
I mean, going back to our previous assumptions, if for instance the "ideal" placement would be right below the tanks, I would not be worried one iota in moving them half a meter in either direction, for practical reasons.
On a 70 footer, I would even think that up to one meter in either direction, the steering effect of the fins can't be too bad...
But this is yet again armchair engineering. Of course having a pro doing some math is not a bad idea!
PS: Re. the thickness bets, I'm aware that my value is pretty high, but it's based on stories which I heard from various yards about "overbuilding" during the first years of GRP, coming from wood construction background.
Some of them even told me that they consider the GRP hulls made in those years among the stronger plastic hulls ever built.
Besides, BA is pretty heavy for her size...
...We'll see, I'm indeed curious. But I'd be very surprised if BA bottom would be less than 40mm thick.
How about the plug that gets cut out for the fitting of the stabs! You just know this project will happen so the prize should not take too long to deliver!But Vas is right, we need an award.
Ideas, anyone? Other than the old virtual mars bar, that is...!
1. I cannot see how CMC claim a floating centre (like Sleipner's) unless they are powered up. Without electric current, they are free to flap, unless they have a locking pin which (must have a fixed, not floating, position), or a clutch (which i doubt). In contrast, Sleipner have a floating centre with no power draw, just by shutting the valves. BartW, do you know about the locking arrangements on CMC? You would expect they are built to be safe and allow the boat to go astern with a failed genset, which surely means a locking pin?
2. Sort of to state the obvious, the CMC stabs need the genset all the time. you cannot run long passages without a genset and just use the engine PTOs to power the stabs. That's a pity, but I guess worth living with to make up for the easier installation of electric stabs compared with hydrualic, at least in a retrofit case. As we all know, boats have lots of compromises. The Italian market (Sanlorenzo) wont care about this becuase they build boats that always need 230v when underway. Other markets will care. Now a 230v alternator running off a main engine would be interesting here so you can stop the genset.
3. Reference armchair engineering, remember Princess fitted 1m sq fins to their current 72 hull back in 2010, under the master cabin becuase that was easier, against the advice of the engineers and architects. At sea, the bow of the boat lifted. They had to move the fins back and they put them under the wing fuel tanks, urgh. To do this they lifted out a pair of Cat C32 and the fuel tanks, on a finished boat, would you believe. And patched up the holes. This proves you can get it wrong because they wouldn't have done all that engines-out work if it wasn't necessary
How about the plug that gets cut out for the fitting of the stabs! You just know this project will happen so the prize should not take too long to deliver!![]()
Well, neither the gyros nor the hydraulic stabs would run without the genset while at anchor, anyway...I will rather be more annoyed running the genny’s at anchor when we want to have a swim
What valves? My Naiads are free floating whenever turned off, with no need to do anything.Sleipner have a floating centre with no power draw, just by shutting the valves.
