SSB installation
Koeketiene
24 Sep 2003
Le Roussillon (South of France)
www.sailblogs.com
I recently bought a SSB radio (Icom 710). Have been going over installation requirements etc... . Not as simple as I tought / hoped.
After talking to several SSB owners I decided against installing it myself. There seem to be so many things that can go wrong.
Would look to have it installed by 'professionals'.
Q: anyone know of a UK firm (south east) that would take on / are up to this job? It would help if you have first hand experience of their work.
Many thanks
snowleopard
Oxford
for grounding, which is far and away the most important part of the installation process, icom sent me a document covering the options. the simplest one is to fit a sintered bronze earth plate and connect it to the ATU with a copper strip at least 2" wide.
run an insulated lead from the ATU to the insulated section of the backstay. the effective length of the antenna is the backstay plus the lead length.
DrBob
22 Dec 2004
..back in Lagos
www.ronautica.co.uk
Poor grounding will manifest itself as increased RFI and possibly poor tuning on the ATU. I use an MFJ Artificial Gound (MFJ931) which connects between the earth wire and the ATU. It totally removes stray RFI and converts a poor earth to a good one even at high power (+1KW).
You may find one cheap second hand.
Dr Bob
www.gm0eco.com
Sea Devil
19 Aug 2004
Boulogne sur mer & Marbella Spain, Guadeloupe
www.youtube.com
The back stay insultaion is really easy - the insulators are sold by Sta-lock (probably norseman as well) . Just use the halyard to keep the stick up - drop the back stay - do a little simple measuring to allow for the extra length of the 2 insulators - make the bottom one high enough for people not to clutch it when you tx. Take a good hack saw - insert the two insulators following the simple instructions and thats it - do not worry too much about length as the ATU will take care of that.
As someone else posted make sure you use 2" copper strip from the ATU to the ground plate - either your keel bolts or a dynaplate. Probably the trick is to position the ATU as close as possible to the ground plate. or VV.
If you order the ready made connections from Icom - you've cracked it - simple wire runs. I have installed 2 and reularly chat across the pond - If I can do it so can you!
