yachtbits
I'll reply to multiple posts here, with answers and some options.
1. in an ideal world, the RFU will be mounted beside the rudder post, with its arm parallel to the tiller arm. The link bar will be attached to both , an equal distance from their pivot points. (real world does not always equal ideal world)
2. dunedin, did the dealer test the drive whilst onboard and did he conduct a full recommission and seatrial??
3. "just a matter of the correct settings..." There are 3 variables in the installation and set-up of an autopilot that are completely out of the control of the manufacturer. a. the boat, b. the installer, c. the user. Therefore, there is no standard settings.
4. a correctly installed and serviceable SPX-5 autopilot is more than capable of maintaining course holding down to a matter of meters. I've commissioned numerous autopilots including SPX-5 wheel in the river at Lowestoft, which is only around 75mtrs wide. I expect to be able to set a zig-zag route on the plotter and the pilot to follow it even in this amount of space. A 30-40 foot fin keel yacht, I would expect to be able to do 180° in this river, just by changing the heading on the pilot, under motor, with or without RFU. If you are not achieving this, you have a problem.
5. comparison to smartphones - Apple said it sold a record 47.8 million iPhones during the 13-week period ending Dec. 29, 2012. With that kind of volume they will be smaller, cheaper and more advanced, but they still can't drive an autopilot drive.
Conclusions:
We have established that your pilot does not work as expected, even under motor.
We can eliminate the "boat" variable as a cause your boat is a standard fin keel with lewmar/whitlock steering.
So, there are 3 remaining possibilities.
1. It has not been installed and commissioned correctly correctly
2. someone has buggered up the settings
3. the SPX-5 course computer is faulty.
I suggest you get someone to help you recommission the pilot, right from "page 1". One set of eyes for the boat, and one for the pilot (and handbook)
If it still fails, contact Raymarine Customer Service, re: course computer fault.
Once your initial issues are resolved, I would however still fit the RFU, particularly on a lighter fin keeler like yours.
I've said all I'm going to on this matter, it is up to you if to take or ignore my advice.
Kevin
Conclusions:
Kevin
