ducked
This is secured with screws from the inside of the boat into the back of a half round teak section. Most of the screws seem to be bronze, but some seem to have been steel. These steel screws are of course no more, and some of the bronze ones have broken or pulled out of the timber as it straightened. The same technique is also used (on a smaller scale) for the "eyebrows" at the cabin top, some of which dont look very secure either, but only one rubbing strake section has so far sprung.
I'll get some pictures when back at the boat, probably tommorrow
Possible repair techniques seem to include:-
1. Removing broken screws and replacing, perhaps screwing into plugged holes in the clamped strake, and/or making a psuedo-timesert thread insert in the holes with copper or stainless steel wire.
However, the heads of the screws inside the boat arent visible and, while I have to investigate further, I suspect I'll have to deconstruct quite a lot to get at them, and then they wont budge.
2. As a possible alternative, drill out the screws from the outside using a tubular drill slightly larger than the screw diameter, and then secure the rubbing strake either with deeply (say half thickness) countersunk bolts (bronze or SS) OR trennels.
Tubular drill bits dont seem to be as much of a thing as I would expect, given how often drilling out fastenings arises as a (difficult) problem, but they do seem to exist.
For example, these look like they might work, if a little larger. These, at max 3mm (I assume OD) are for fine jewellry -stylee jobs and a bit too small. The jive about drilling underwater will also have to be considered innapplicable unless I sink the boat.
Small Diamond Core Drills 1–3mm | Glass, Sea Glass, stone & Ceramic
I like the idea of trennels but I've never made any so it might be more expedient to use countersunk bolts. I shoiuld be able to get away with using fewer than the screws they replace since they should be stronger.
Whaddya think?
Whaddya think?
