Not exactly easy to help with so little to go on. Many modern aluminium winches use pawls with a common pattern pawl spring that is a tiny double loop with a couple of legs. These are obtainable from major winch manufacturers, often they'll just give you a couple. If your winches are unmarked, presumably they are the old bronze or tufnol types, which used all sorts of springs.
Best bet might be somewhere like Aladin's Cave in Bursledon to see if you can spot a similar old winch. If you have a spar or winch maker in your area, they sometimes carry old bits and pieces of this type that they'll look out for a personal visitor.
Otherwise you may be stuck with buying new winches.
