KREW2
Can you treat them like gelcoat, lightly polish/compound and then wax?
We have Awlgrip paint and never put polish on it. Once you start it's like painting the Forth bridge.
Awlgrip has it's own set of rules to follow, if indeed it is Awlgrip and depending on which one was applied.
If it was applied correctly then it should not have failed so early, Awlgrip has great UV inhibitors and has good resistance to scratching, but even Awlgrip has to be subject to correct cleaning techniques.
It can be corrected, but it's not as easy as gel coat, I could make suggestions but it would be a guess at which compounds, paired with correct pad would work the best without testing.
Any pics to tease?
Quite possible it's not Awlgrip, this may account for the premature failing, It's applied quite heavy with a wide nozzle, so usually an orange peel effect present.
Whatever it is I will find out, def not orange peel effect, it looks almost like gel coat.
It hasn't exactly failed, just a few unsightly scuff marks and scratches that don't seem to wash out.
Yes sorry, wrong thread on my mind for the failing
Sound unlikely to be Awlgrip
