Spontaneous combustion.
Boater Sam
14 Mar 2020
Philippines and Thailand
An associate of mine used to ship swarf scrap around the world in old ships that were scrapped at their destination.
He lost a few over the years due to the swarf oxidising in wet holds and setting uncontrollably on fire
Alex_Blackwood
19 May 2003
Fareham
Thank you ... was otherwise engaged - sorting out Beware of Dog signs for me new fence ... 3D printing.
Flash Point ... Open or Closed cup depending on product being tested as VicS says - is the temp at which the vapour produced at surface of product will ignite when ignition source introduced .. such as a sparker or flame.
VicS said:
No the flash point is the temperature to which the liquid must be heated for the vapour above it to be ignited when a flame is applied.... but under very specific conditions such as in a Pensky Martens closed cup flash point apparatus .
What Refueler is describing would be the "autoignition temperature"
Thanks, both of you! I knew I didn't have it quite right, had forgotten all about PM. Been retired too long :rolleyes:
Aja
6 Nov 2001
I've seen a post on FB about a yacht fire that was thought by the Fire Brigade to have been started by spontaneous combustion of a rubber dinghy stored in a cabin. Has anyone else had a similar experience? The FB thought it is was due to reaction of nitrites in the rubber with traces of grease. There was no other source of ignition.
Back in the dim and distant past I worked for Templeton Carpets.
In the weaving shed the tenters and weavers were constantly blowing away what was basically wool dust using compressed air lines. Reason was it occasionally burst into flames.
Not as frightening as a shuttle firing out a wilton loom...
