Splicing thin braided line
Poignard
23 Jul 2005
London and Brittany
My Monotor windvane has to have an small diameter endless line around the large pulley wheel to adjust the course relative to the wind.
I couldn't find any way to splice it when I installed the windvane so, as a temporary measure, I overlapped the ends and stitched them together. It is still in use.
If I was doing it again I would cut back the inner core on one end by an inch or so and cut back the outer braid for an equal amount on the other end. Then insert the one into the other and stitch it up.
Refueler
13 Sep 2008
Far away from hooray henrys
In theory you can splice it .... by dividing not only the core from outer braid - but the parallel core strands as well. But its not secure.
The post #3 advising to sew is better ....
My usual way with such is to sew it together and then run the thread round creating a neat whipping over top.
lw395
16 May 2007
Practically, is anything splicable at 3mm diameter?
Yes, there is a lot of 3mm and even 2mm spectra about which is just a 12 stranded braid. That splices very well.
4mm Excel racing or whatever it's called this week is a braided cover over a braided dyneema core and can be spliced very well, I have it in continuous loop controls on the dinghy.
Upnorth
29 Aug 2005
Durham & Port Grimaud
This is instructions for parallel core splice, dont know if it works on your rope
Sta-Set X/PCR Splice - New England Ropes
Thanks for that. The nearest link to cope with the line I have. I think the statements about 'it maybe impossible to bury the cover' will probably be the big issue. As in the other helpful suggestions, I think will go down the stitching/seizing route.
Thanks again everyone for your responses.
