Speedseal O rings
Measure the groove dimensions. O-rings of all sizes are on ebay. It's also easy to make a bespoke o-ring for a speed-seal from o-ring cord, again from ebay, and super glue.
When you get home I would greatly appreciate the measurements.
And hopefully others will appreciate too. I have a list of pump coverplate o-ring dimensions that I have gathered, not all Speedseal, many Johnson pumps had o-rings sealing the coverplate as standard. Any more, anyone?
Volvo Penta MD1 Speedseal Cover Plate = 1.5mm x 42mm ID nitrile
Vetus M3.10 Speedseal Cover Plate = 1.5mm X 51mm ID
Johnson pump F4B = 2.4mm X 49.6mm or 2.4mm X 54.6mm ID or 2.4mm X 59.6mm
Johnson pump F5B = 2.4mm X 57.6mm ID and 2.4mm X 59.6mm
Johnson pump F6B = 2.4mm X 57.6mm ID
Volvo Penta TAMD41P-a which is a Johnson pump F7B = 1.78mm X 63.22mm ID
Johnson pump F75B = 2.4mm X 64.6mm ID
Volvo Penta 2003B cover plate = 1mm x 40mm ID
Www.solocoastalsailing.co.uk
I will oblige :)
I just bought a second speedseal for the 4108 (see recent thread, most of the models are still available from the French distributor ATMB Marine, rather more expensive than formerly in the UK though), now it s school holidays in France I am stuck in the middle of the Alps, will be back home at the end of the week.
As promised, here it is :)
The OD diameter of the groove is 60mm, the internal one 57.5mm, oring rope dia 1mm
I add a cross reference with engine type, pump type, johnson impeller number, jabsco impeller, speedseal reference, source ATMB catalogue
Just took a night picture, if it is not visible and if any interest I can scan the page
The Perkins 4108 speedseal reference is DUNC
regards
View attachment 76270View attachment 76270
regards
Excellent. Thanks, but the cross reference image is not very clear........
www.solocoastalsailing.co.uk
