Mr Cassandra
I have two 100w panels join to the control the output is 18v. However the batteries are only showing 11.7v. When I run the engine this goes up to 13.4v.
Ideas please
Ideas please
Ideas please
The same 11.7vWhat is the battery voltage with the solar panels disconnected?
Yes, theres a dual controller for both banks.each read the same.both green lights are solid.Do you have a controller on the panels? If the battery are significantly discharged the controller might be in bulk mode and will be putting as much amps as possible into the batteries at a voltage which is only slightly higher than the battery voltage.
The alternator is not smart and will put out whatever voltage its regulator is set to.
Richard
Ideas please
Do you mean "I have two 100W panels joined to a controller"?I have two 100w panels join to the control the output is 18v.
Measured how and where? 11.7V (from a rested battery) is pretty much flat, although I daresay yours are under some load.However the batteries are only showing 11.7v.
Sounds like a pretty ancient alternator regulator. Modern ones usually reach 14.4V or so. 13.4V is going to take an age to fully charge your batteries, if it ever does.When I run the engine this goes up to 13.4v.
the batteries are only showing 11.7v.........
Ideas please
Bring the subject up again on your return after having checked and recorded voltage of each battery when connected on its own and when isolated with a 12v bulb strapped across it.Unfortunately I am leaving the boat on its mooring tomorrow for a month.
This was a last check round before leaving
My rule of thumb is 12.7 volts equal fully charged. 12.2 volts empty, but I can start my 18hp engine on that.
