Caladh
I've recently bought an MPPT controller for my 4 solar panels and queried with Morningstar whether I'd be best to wire them in series instead or parallel. Their answer is below. However I was unaware that wiring in series was not good in reduced/shaded lighting conditions.
"Series Wiring of Panels"
Connecting solar panels in a line, or series, allows you to build up the voltage to the level you need (as opposed to parallel wiring which allows you to increase current).
The major limitation of series wiring is that performance is adversely affected if all its cells are not equally exposed to the sunlight or some of them are partially shaded. Whether this shading is caused by a neighbor's trees, leaves falling on the panels, snow, or bird droppings, you may lose between 20% and 40% of the potential output of your solar installations because of shade.
"Parallel Wiring of Panels"
Solar panels in parallel are less affected by shading as compared with solar panels in series. That said, shading is never a good idea and can lead to damaged panels before their natural lifetime is over (which can be decades!).
