billcole
I made up a goalpost-like support from straight 25mm tube and bimini fittings plus a few bits of iroko. It's clamped to the pushpit with u-bolts.
The boat's out in Greece, so I can't post a photo, but it's like a Greek letter pi, with the uprights clamped to the pushpit, and (for stiffness and strength) the joints of the pi braced across at each side to the bimini with two tubes about 600mm long. The horizontal of the pi has four pieces of iroko with 25mm holes drilled in the middle and threaded on to it at right angles and roughly evenly spaced out, with two more tubes threaded through the ends of those, so I have three parallel tubes forming the top of the arch, which can be pivoted about the middle of the three to follow the sun (in one axis only).
The solar panels (4 x 25watt and 1x50watt ) are clamped to the "shelf" formed by these three tubes, and two 6mm lines, one from each of the outer tubes, are tied off to the pushpit to hold the three tubes at the chosen angle to best face the sun. I usually leave the panels horizontal for most of the day, but can improve the power generated by tilting them to face more east or west as necessary nearer to dawn or dusk .
