Nostrodamus
Until you want to roll away the bimini!
But yeah, it's great having a panel there.
Thought you had one there Cardo and it worked well
Not convinced...
You can already get leccy from sails... Via a towed generator.
You can already get leccy from the sun... Via normal solar panels.
as proposed by Arthur C Clarke in the 1970's.
Sure, but the former increases drag and the latter is limited in size. I do agree that cost will be critical, but look at the scale PV manufacturing and generation sector where real costs have collapsed through innovation and mass production. Start-up technologies often follow an "S" curve; no reason to assume that this will be much different.
Mike...
Absolutely 100% totally agree. Now what the hell are you talking about?????????????
Can you wire a plug for me
I think the point I am trying to make is that this is a cure looking for a problem.... With new led lights, lower power instruments, etc... There are good opportunities to reduce consumption..
Costs associated with producing leccy is coming down, solar is cheaper, and wind is as well...
So unless they can do this at a very low cost, I just can't see how it would be attractive over the existing techs... Which are getting better and cheaper....
Photodog,
maybe, but I look forward to the day when electric propulsion is viable for yachts - yes I know it's not green really considering the production of batteries but I'm being selfish.
When considering building new Anderson 22's I was very keen on having an electric engine, but after chatting with a Torqueedo engineer I realised it's still only possible with a boat designed for it, something like a long keeler using the batteries as ballast - still close to a U-Boat !
However with photovoltaic sails I'm sure silent and high torque ( auxilliary ) propulsion will happen one day.
Since it's technically possible to generate hydrogen from seawater using electricity generated by solar power and to then use that hydrogen in a fuel cell to create power to drive an electric motor, turning it into a workable and economically viable package is just engineering.
The problem with that model is that electrolysis of water to make hydrogen and oxygen is horribly inefficient at usable rates (at very low rates it's endothermic and therefore > 100% efficient as far as electrical input goes) and that storing the gases produced ain't easy unless you compress them, and even then it ain't easy. Basically, going from electricity to hydrogen just doesn't make thermodynamic, economic or engineering sense.
Better and cheaper batteries are the thing to hope for. When a battery pack for a Tesla costs £5k instead of £50k, we'll be getting somewhere.
I know someone who is converting a Victoria 800 to electric propulsion. He has made a very neat job of it, using a Lynch motor and (iirc) two 200Ah lead acid traction batteries. For the same weight he could fit around 8 Mastervolt 5000Wh lithium ion batteries which would give around ten times the current (haha) capacity ... but alas at a cost of around £35k for the batteries.
But however it ends up turning out - whether an improvement on existing technology or something new and better - as sure as eggs is eggs the future is electric. The only real question is when, not if
any idea of the range / endurance your chum will get from his electric Victoria ?
... something like a long keeler using the batteries as ballast - still close to a U-Boat !
