Tim Good
I’m not exactly sure of the correct terminology or if angle of incidence is even the right word. But I’m trying to figure out what angle of the sun on a horizontally laid panel will produce what efficiency or percentage power output.
For example in northern Spain at the moment at solar noon the Sun is altitude is around 31%. currently we are only getting about 50% if max power output and I’m curious if there is a graph or calculation which shows what you should theoretically get at a certain angle. Clearly 90° Solar Altitude to a panel where the Sun is hitting the panel head on his best.
