sailoppopotamus
Current setup:
- A house battery (AGM 2x150Ah, 12V, in parallel) and an engine/windlass 80Ah battery (VRLA, non-AGM, possibly due for replacement).
- 2x100W 12V panels in parallel
- A single-output Victron PWM controller
- A Sterling 2-output mains charger
- A Victron Argodiode
The PWM controller charges the house batteries. The alternator (stock Yanmar 2GM20F) goes to the Argodiode, which is connected to the two batteries. The current setup is sub-optimal because the engine/windlass battery is chronically undercharged (due to diode voltage drop, not running the engine for long enough to replenish charge lost in starting it and weighing anchor, and when the boat stays on the hard for months away from a battery charger).
I would like to improve the setup so that the engine/windlass battery is also charged from the solar panels. I would also like to upgrade to an MPPT controller. My options from cheapest to most expensive look like:
1. Connect the MPPT controller to a Victron Cyrix combiner, which is then connected to the two batteries.
2. Connect the MPPT controller to a Victron Argofet VSR, which is then connected to the two batteries.
3. Connect the MPPT controller to the house battery, then a Xantrex Echo Charger to the starter battery.
Is there any reason why I wouldn't go for the first option? I realize that (1) and (2) require similar battery chemistries, so I'll have to swap out the engine/windlass battery for an AGM one if I go down this route. Will I have to modify the alternator wiring in any way? Also, this might be a stupid question, but can I remove the Argodiode entirely and connect solar and alternator to the same Cyrix combiner, or is that likely to cause problems?
I would be grateful for any feedback/help with this.
