pmagowan
You need to draw a schematic. The wiring is definitely atypical and your answers do not provide sufficient information to understand it.
Amended thanksI'd be careful making simple statements like that, there could be all sorts going on, on a boat of this vintage that's been modified over the years.
Hello Tarona What is a SHUNT is that a splitter? Your text the shunt is fitted between the house negative terminal and the cable as it measures all the loads going out to provide the data for your monitor. The Solar company suggested a trickle charge from the Domestic to the Starter batters maybe around 1 or 2 amps Salesman says it may take approx 2-3 days to chargeHello Tarona Oops I forgot your Question.
BOW THRUSTER Powered By the Domestic Batteries THAT IS the GREEN cable runs from Domestic Batteries through the boat to the BOW where is connects to a Battery and Battery Charger. The Green Cable is Only used to Charge the Battery in the Bow.
It was installed 2017 In Torreveja as the old one Corroded off.. The Mechanic that installed the New one Did not provide enough Power he installed 2 x 15mm Cable It blew the 500amp fuse a few times - So in PALMA a Company installed a Battery and Battery charger in the BOW
WINDLASS I have only ever used the Anchor Once.
YES it draws a lot of Energy I kept the Engine Running The Battery charger 9Sterling Power then works overtime)
May I respectfully suggest that you purchase a few books on basic DC/boat electrics and take time to read up on the topic.What is a SHUNT is that a splitter?
